Front Driveshaft, need special T-40 Tool
TIPM Control Module
Identifying an 11.50 rear axle?
Last week, I started having a small vibration. I thought it was the trans, as I only noticed it in overdrive. Then, It got worse and I figured out what it was: The front drive shaft. While trying to baby it home, the centering ball (I would call it a CV joint, but other disagree) came apart.
I didn't have any Torx bits with me, so I had to call a tow truck. I took the truck to work and took the shaft out (I am now driving a 2 wheel drive truck).
One problem I encountered was getting a torx socket for the front drive shaft connection seated properly. No matter how I approached it I had a little angle with the socket (because of the mass of the socket). As a result, I stripped one of the heads out. Had to drill it out and add an hour to an already long day.
I got the shaft rebuilt by a machine shop locally (about $270, new joints all around, with grease fittings) and new front bolts from the Dodge dealer ($20 for 4).
I want to get a long T-40 socket so I can properly seat the socket in the bolt and not strip one out again. Any suggestions?
Um, call me silly but, why replace a stripped torx with another torx that has the same inherent PIA design? Replace them with real bolts and eliminate the problem.
Wish I could have suggested this earlier, but when mine went out I got a completely new front driveline from the dealer for $250, could haved saved you a little money, and I had the same problems with the torx bits.
I got a set of long torx that work from harbor freight.
I still stripped one out removing it.
Went down to the hardware store and picked up some 10. 9 flanged head bolts, no more issues.
Apply some heat with a butane mini-torch and they will come right out. The factory put some decent thread-lock compound on them. Don't forget to re-apply thread lock when you install the new bolts.
Just my . 02
I use Snap-On FTXL40E that is just a little over 4" long. If you turn the shaft correctly you can get a good angle on them. I keep a couple of bolts in my box just in case.
