My 02 2500 is having axle problems. Last month I had the pass. side axle shaft Ujoint freeze up, no big deal, got a new one and pulled the hub assembly and shaft and replaced it. Problem solved, till Tuesday, I made a left turn out of work and the driverside wheel bound up and actually skidded/chirped around the corner like I had a locker! Not a brilliant driveline guy, but I thought that maybe the OTHER Ujoint froze up(similar problem) so I got out my spare Ujoint and picked up a hub assembly just incase(WOW, $250) replaced both of them(the bearing had some play in them) Took a test drive, first corner still the same problem, inside tire chirps/binds, regardless of which direction I turn. Front end also hops around like its in four wheel drive, though alot more pronounced. When I checked the gears last time visually inspected everything in the front diff. and nothing caught my eye, even added new fluid of course. Anyone with more axle experience than me have an idea? This seems to be alot more than a simple frozen Ujoint cap like last month. I need help quick, this is my daily driver and I don't have a backup! Did I possibly install something wrong? Added a squirt or three to each Ujoint and they moved effortlessly prior to the install, I'm at a loss guys. HELP!
