front end noise found
My 2004 6 speed shifts very hard WHY
My TST Install...
When you brake hard at slow speeds or go over speed bumps and hear a clunking noise like a loose component in the front suspension, if you its nothing big so don't worry. The problem is the coolant tank is low and the movement of the vehicle makes then fluid slosh around and make noise, just fill it up and keep runnin your cummins :)
