OK, I've got 4 trucks and have had these apart, cleaned re-greased and re-installed with no problems expect for how hard it was to get the darn thing off the truck.....
After reading one of the old threads - here is what we did... .
We used an arbor press to take it apart, washed it in the parts washer and repacked it with the same synthetic grease we use on our clutch bearings... This grease has a melting point of 500*F where the average bearing grease is closer to 300-325*F.
Once you have rotor off and the ABS sensor off you can install a needle grease tube into the bearing and grease it with say 8-10 pumps from the grease gun... .
We actually greased one by hand and than took it apart to see if this works... and yes the grease gets to both bearings... .
Upon installation on the truck we coated all the parts with anti-seize and re-installed. .
We have high mileage trucks and wanted a method of greasing these bearings every year or so... . we used a full synthetic grease as these are close to the brakes and heavy breaking will allow some of the heat generated to migrate to the bearings...
We looked at trying to install grease fittings... and found no portion suitable for this... its either where the bearings are, covered by the other parts of the truck upon installation, or hard to get to... etc... we just decided that we'd pull the caliper, and rotor and the ABS sensor off and grease it...
On one of the trucks, I guess we have 100k miles on a new hub on one side and a re-packed hub on the other side...
I'm happy with the results but have found a vendor for these parts. . and will have them on the shelf in 45-60 days...
Since I wrote this I went back and looked at the photos by CumminsPower98... . and think he's on to something... I didn't think about this location and the next time I have one apart I'll look at it... thanks for the idea. .
