Ran into trouble late in the day. Have had an intermittent hum that is getting more noticible. So upon careful hrs of inspection (completely disasembled rear dif... , found front driveshaft u joint is a little loose and also the axle ujoint is dry and has some play. We got the spider nut (1 5/8th nut off hub,the four #18 bolts off the back and THOUGHT with some persuasion the assybly would "come to daddy". It won`t budge so do we have to take the rotor off, is there something else holding the frnt hub assybly ?
Caliper... is all removed. Maybe it takes a big puller with some tapping ??
