Have an oil leak. It doesn't drip when sitting, but is concentrated all around the front of the oil pan and drivers side of the oil pan there is a coating of oil. The oil is also all over the power steering pump.
I don't see any oil directly under the harmonic balancer, (front main area), but am still concerned it might be leaking form the top of the front main seal. The oil seems to be too high up on the engine to just be a pan gasket. I'm not too experienced with this type of leak.
Any ideas or similar leaks?,
(BTW, the power steering fluid level does not change. I've been watching it for a while now)
97 2500 Reg cab 4WD, Emerald Green and Driftwood, 3. 54 gears, 2" Daystar Coil Spacers, 315/75/16 AT BFG'S on Alcoa's, Trailmaster SSV shocks & SSV steering stabilizer, K&N, stock, oh yeah--no silencer ring
K. Kinion
K. Kinion
