Just follow the install instructions, make sure your crank is clean of ANY oil. That Teflon must be transfered to a dry clean surface. Use the install guide included in the kit. suggestion, use some guide pins to help install the cover back on. Same size bolts that you remove from the cover, just a couple inches longer, cut the heads off, and campher. [round] install into bolt location, install cover.
just my penny's worth.
Marv.
