2nd Gen Non-Engine/Transmission Front wheel bearing OMG
2nd Gen Non-Engine/Transmission exhaust/stacks question.
Engine/Transmission (1998.5 - 2002) Driveshaft removal, how?
I may do rotors if it isnt cost prohibitive.
The ball joints were checked out less than 5K miles ago and given a good bill of health. Even with 120K miles on em. Adding my own zerks payed for themselves many X's over. :D The upper joints are nearly impossible to get to, but some grease is better than none. :-laf
[Never mind this post. I'm wrong; see SSL's post and mine, below. ]
'98 4x4, the hub and rotor is a single unit. If you replace either, t'other comes with it. They are not intended to be disassembled for service.
Only thing I can suggest might be to thoroughly degrease the new rotors then use an orbital sander with suitable Al-O2 sand paper to scuff up the rotor surfaces a little. Then clean them again. Then install and clean yet again. You can't try hard enough to get all the grease off the brakes.
Are you sure? I can find the parts seperated, but not as a unit.
Dam, I wish I could find the shop manual. #@$%!
On my 98 they are seperate. You may think they are one because it's so hard to press the studs out but they aren't. I had to use a 30 ton shop press to get them out. No amount of penetrant, beating, u-joint press, etc would budge them. They popped like a gun going off when they finally let loose. The wheels studs are pressed into the rotor and hub.
Thanks Steve. I somehow missed your post. :D
Ah. This may be why the rotor and hub are sold as a unit. I had been lead to believe they were a single unit. But now that I check my SM, I find I've been mislead, and wrong. (Damn, that's the second time this year! 2009 does not bode well for me. )
This is what I've been seeing.
http://ecx.images-amazon.com/images/I/41pSm%2BFORuL._SL500_AA280_.jpg[IMG]
That's why I asked when you said it's one piece. :D
Thank God!
I took it apart today to give it some Kroil.
When the wheel was off I saw a very shiney spot on the disc brake dust shield.
Sears put them on a little off center. :cool::cool:
I lubed everything up and put it back together and no noise!!!
