Fuel additive = +20% mpg, +10% hp, -70% emissions, lower EGT?
Jacobs "ENGINE" brake question vs Jacobs "EXHAUST" brake
Baldwin BT7339 filters any good?
Okay, now that I have your attention!
I have been lurking for a while and thought that I would pass on this article taken from Science News. This magazine is a hard-science weekly magazine that gathers and condenses siginificant results reported by scientists in all fields of science. If anyone else here reads this magazine, they can vouch for it's scholarly accuracy or you can just go to the library and look at a couple of issues and see for yourself.
Anyway, I thought that the below article might shed some light on the functioning of propane injection as well as point out another area we might be looking at.
Now, who can get us some polyisobutylene?
-John-
Science News
September 2, 2000
Vol. 158, No. 10
Pg. 149
By J. Gorman
A chemical normally known for its role in the manufacture of synthetic rubber may lead to cleaner-burning, more-fuel-efficient cars and trucks.
Automobiles using the polymer additive, called polyisobutylene, decrease their emission by 70 percent, says Paul F. Waters of American University in Washington D. C. What's more, mileage goes up 20 percent, while horsepower increases 10 percent, he says.
Due to emissions improvements and fuel savings, Waters says, polyisobutylene "reduces the number of gases that potentially lead to global warming.
Waters reported the results in late August at the 220th national meeting of the American Chemical Society in Washington D. C.
Gasoline is a menagerie of hydrocarbon molecules that differ in size and shape. Short molecules generally burn very quickly, causing temperature and pressure inside an engine to rise in a dramatic spike. That creates engine knock and emissions of nitrous oxide pollution. Meanwhile, longer hydrocarbons burn more slowly and incompletely, which raises exhaust temperature and leave remnants of hydrocarbons that contribute to soot and other forms of pollution.
Polyisobutylene appears to lightly delay the burning of short hydrocarbon molecules, which then hasten the burning of the longer hydrocarbons, Waters says. With the additive, therefore, the fuel burns more completely and engine and exhaust temperatures drop significantly.
Waters suspects that polyisobutylene changes the surface tension of fuel droplets, preventing short hydrocarbons from immediately vaporizing when gasoline is prayed into the engine. The delay is apparently "long enough so that… the two components evaporate more or less in the same physical region in space and then they burn more or less together, says Waters.
I think Paul has some intriguing results that could e very promising for the automotive industry," comments Graham Swift, a polymer chemist and independent consultant outside of Philadelphia. "It sounds delightfully simple and promising to me. We tend not to look for simple solutions. "
"What I like about his approach was that he looked at combustion, and he looked at what controls combustion, then applied it to the internal combustion engine," says Swift. With better control over the fuel droplets, Swift says, "the better your combustion, the better your fuel consumption, the better your automotive horsepower, the less incomplete combustion you get, and that means that you've got less noxious fumes coming out. "
So far, Waters and his colleagues have tested the additive on a dozen automobiles in three states and several other countries. Waters points out that 50 other cars have also shown improved performance with the additive.
Waters says the mileage benefits could pay for the cost of the fuel additive - perhaps 10 cents a gallon, he says. Polyisobutylene works well in diesel engines too, he adds.
"This is of course useful for global warming, but it is also useful for the vehicle and the engine itself," says Waters. "When the engine operates at a lower overall temperature, there's less wear and tear on all these parts. The less temperature that you impose on any of these devices, the longer they're going to last, and in principle, the less your repair bill is going to be.
Dodge 2500 Cummins 24v 4x4
I recently picked up a brochure at a truck stop on a product called DurAlt.
Here are the claims:
1. Removes combustion deposits from inside the engine.
2. Reduces Hydrocarbon emissions from 10-43%
3. Increases horsepower by at least 5% across the board.
4. Gives an average 8% fuel mileage increase.
SAE/NIPER tested
The brochure refers to it as a lubricating combustion modifier
"By combining a combustion modifier with a polar compound that reduces combustion deposits, a more complete fuel burn is achieved-which in turn provides cooler exhaust temperatures at the time the exhaust valves open"
I dont know how much this stuff costs nor i have i tried it myself.
joe
I researched this topic for a week, and finally got ahold of Dr. P Waters contact person. He is supposed to send me a sample soon. He said in his mail, that it is currently being tested and should be on the market soon. ( Soon to a scientist, who knows?)
I'll keep you posted. There is also a post about this in the "other" area.
1997 3500 Dually CC, Emerald Green 5 speed, 4:10 , Reese 15K 5th hitch, K&N Air Filter, Jacob E-brake, gutted cat, running boards. Maybe more,if I can keep it out of DC'$ hands. .
thanks bugout, i e-mailed the chem dept. at american u and didn't get a reply. i'm too cheap to give them a call. keep us updated.
wonder if this will void the warranty?
JUST JOKING!!
Bug Out,
I found the thread finally in the General Diesel Topics forum.
I also did a bit of web snooping and found a website describing the properties, uses, and history of polyisobuylene.
http://www.psrc.usm.edu/macrog/pib.htm
It turns out that this is a very common and well known polymer that when cross linked becomes synthetic rubber. Think tires.
It seems to me that the remaining remaining variable to be worked out is the length of the polymer chain that works best for this application.
-John-
I just talked to Joe at the Pitstop and ordered a case of the 16oz. btls. to try. He said you don't need inj. cleaner or lubricity add. with this, only an anti-gel when its cold. They also make an additive that includes the DurAlt and anti-gel in one. If you figure per-gal. cost, this is less than a lot of the other additives out there without the benefits of DurAlt.
Sounds good to me, its on the way, let you know later.
Larry.
Y2K 3500 QC,SLT,4X2,White, 6spd,3. 54 lsd,Banks Stinger +,Pacbrake,Pilar mt. EGT & Boost,Amsoil air filter,all amsoil lube w/BMK-15 filter system,MagTec rear cover,putco boss rbs. w/ rear ext. &flaps,20K reese,100 gal. aux. fuel,fold up T cover,5K airlift bags w/comp. ,ranger 2950 cb pushing palomar 225 amp,phantom radar det.
SAE/NIPER tested
joe
DurAlt is sold as an additive at Harley Davidson Dealers, packaged in "Harley" containers which also say DurAlt on the package. Harley Recommends it in the bikes. I have used it in my bike mainly for it's fuel stabilizing feature since I don't ride often these days. I cannot claim any significant fuel mileage increase - but I have not really kept a close watch on it. I did not know it was marketed for other vehicles.
BZIN, I just fueled up today, and added the DurAlt, so haven't had chance to check it out. I won't be driving it till I get a load to deliver. Will let you know what I find out.
Larry
Rattlin, I goofed, I installed 275 inj. , and they started blending the fuel just before I got the DurAlt, so I can't really give any good info. I used up the case of 12oz. bottles that I got, and just got a case of 4, 1gal. bottles. I'm going to keep using it, hopefully when we get back to using good old #2 again, I'll know more. The winter blend has knocked my mileage down 2-21/2 mpg. Just turned 101K on trk. on last trip to Inverness Fl. , just getting broke in good.
Larry
YogiBear,
I hear ya'. It's tough to know if what you have done makes a difference when the weather and the fuel change at the same time. I'll look forward to hearing from you later in the spring.
Yogibear - What is your opinion of Duralt now that you've used it for a few months. Also, who do you buy from? The best price I've found from web surfing is through Everbest, but it is concentrated for bulk use.
