So, the reality is:
1. There is absolutely NO proof that an additive does anything other than fleece your wallet.
2. NO one (Cummins, Dodge, fuel producers, Diesel Engineers) recommends that you use additives.
3. The manufacturer of the engine (Cummins) specifically advises against using any additive. What would be the point of building an engine that did.
4. ALL the "so called" testimony of satisfied users is purely opinion without the smallest shred of credible scientific data. How do you calculate the performance improvement with data like "gee, it seemed to run better after a while", or "I'm pretty sure I saw around a mile per gallon improvement". Of course the guy who has passed a half a million miles with three different trucks without using a single additive must just be a fluke..... right?
It appears that most additives do little more than fill the pockets of the makers. Although they may not hurt your engine, they certainly don't help it. Shoot, you may as well just add some ATF and moth balls to the tank. That was the rule of thumb for gassers for years... . people swore by that one.
Just my 5 cents fwiw. Besides, I gotta go change my oil... . it's been almost 3000 miles and I feel like throwing away some more money. :-laf
Also, I would point out that Stanadyne Performance Formula is now apparently "Formulated for ULSD".
Ryan
Ryan Are You really changing at 3K? if so we will have to work on that![]()
Ryan, I respect your opinion and enjoy reading all your posts, but changing your trucks engine oil that often is a bit over kill. That's kind of like changing your underwear twice a day when the rest of the world changes theirs once a day.
Cummins Filtration Fuel AdditivesCumminsFiltration said:Cummins Filtration offers an array of fuel additive products to enhance the fuel system performance and support new emission standards. Changing regulations that have lead to the use of biodiesel blends and ULSD fuels have created unique maintenance needs across the globe. The addition of high quality fuel additives is now an important element in every good diesel engine maintenance program.
The 7. 3 & 6. 0 Nav Motors not only use the crankcase oil for lube and cooling, it is also used to inject the fuel, I would recommend 3/5k change intervals. any type of oil that will not foam will work with the nav motors, generally if using High end lubes is just a waste of $$$$. . B/C of changing so often. the 7. 3 on long intervals will lose performance do to the oil degrading.
