Fuel Additives
Turbo Fix
72 Attempted regenerations 2 Completed
According to the owners manual, it is not necessary. I have not used any, 127,000+ miles, no problems.
If it was legal, I'd be running Jet A in my old '93 just because I can get limited quantities for free, and the '93 doesn't really care as long as it resembles diesel fuel and will move through the filter. Jet A is really clean stuff, but a little dry so some lubricity additive would be needed.
I'd be afraid to run anything besides clean ULSD in my '07. 5. Those injectors are sensitive, and darned expensive. Same with the turbo. You don't want anything that might clog up the VVT. They already have some issues with clogging.
In aircraft, some soak the turbo's in Berryman B-12. It's a really good solvent, but I don't know if anything in our VVT's might be damaged by it's use. For now, I've got a warrantee and I don't intend to mess around with the engine. Knock on wood, it's run perfect so far but I may need that warrantee some day.
Additive
I run Amsoil diesel fuel additive and cold flow additive and also thier cetane boost (can mix additives) I ran stanadyne for years great stuff the only reason I run AMSOIL it is DPF compliant Matt 2007. 5 QC laramie Dually 4x4 Briiliant black leer cap tfp door handles banks dual monster exhaust aem dry flow air intake go rhino ss hitch step recon running lights Putco ion chrome cab lights
