Engine/Transmission (1994 - 1998) Fuel bleeding back through the supply line fast!
Engine/Transmission (1998.5 - 2002) standard 5.9 and HO
I got my 97 running finally but it will not stay running because of fuel bleeding back through the supply line rapidly. I know I am getting air in the system but not sure where. I changed the two rubber lines by the engine and the lift pump. I did get the whole system blead out even the return line to the filter. Could the Overflow valve be stuck or not working. Please help. I need this truck for Saturday! #@$%! :mad:
Also could this be the Fuel heater! The plastic is melted and doesn't work anymore! This would be easy if it was the problem!
ok, one problem the new hoseis to small for the supply line! i have bypasses the fuel heater but still leaking air... probably through the fitting i created!
