BSFC measures fuel mass per unit of time per brake horsepower, not per RPM as a previous poster stated. For an engine operating at full load, best BSFC normally occurs at the torque peak (or peak BMEP) RPM. If one's foot were to the floor and maximum torque and BHP were being demanded from the engine, total fuel consumption would increase with RPM, but so would BHP, so unless you go back to a BSFC measurement that takes this into account, it really is a meaningless comparison.
The question that (as far as I can tell) hasn't been answered is - What if I'm running at a constant 60 MPH pulling a 5th wheel (i. e. , a constant load situation). Will fuel consumption be better in 6th gear at 2000 RPM or 5th gear at 2600 RPM (4. 10 gears)? This is a constant BHP situation, so to achieve a given BHP, torque output must be higher when running at 2000 RPM than at 2600 RPM. (BHP = [Torque x RPM]/5252) Higher torque means higher BMEP. Higher BMEP generally means better BSFC. The 2000 RPM situation, in addition to higher BMEP, will have reduced frictional losses, so should produce better BSFC and total fuel consumption.
At the end of the day, the only way to be absolutely sure what the RPM/BSFC relationship would be for a given engine would be to produce a 3 dimensional variable torque (BMEP)/variable speed engine BSFC map on a dynamometer.
Rusty
Rusty
