Yes, this is my first post in 2 years of membership. I like to exhaust the search features of this forum to the best of my ability.
so here is my story...
96' 12v, 4x4 extracab, longbed. 47re rebuilt by me. previous owner took it to banks and had them build it up with the powerpack setup. He was happy, I wasn't... found the afc arm diving under the fuel plate. That fixed alot of problems and triggered the demis of the transmission. Its also running an amsoil bypass filtration setup.
So when I first got it, it wasn't uncommon for me to achieve 600 miles to a tank. then things slowly began to go downhill from there.
things I have done. Timing was the latest thing I had done last week with no significant improvement. Air filters, fuel filters... fuel screen... overflow valve... dropped the tank and cleaned it out... replaced some of the fuel lines.
I see no leaks on the ground from fuel. It doesn't matter if I run petroleum diesel, BioDiesel, WVO or a blend of any of them.
More importantly, the truck runs great. it fuels thru 3000rpm pleanty hard, on cold mornings here in Socal below 40, it starts right up as in less than a second, so that eliminates an airleak in the fuel lines. It does smoke a little for a minute or so but I think thats only because right now I am running 50/50 petrol/WVO.
Off the line foot to the floor I get about 2 seconds of turbo lag or about that much time of smoke out the pipe, then it cleans up and hauls axle.
I'd be alot quicker to change the lift pump if fuel delivery felt like a problem but if I leave the TC unlocked and stand on the stupid pedal from a stop, my egt's will hit 1250 with 32psi of boost. I do notice that I used be able to get 34 psi of boost.
I find no leaks from the turbo to the intercooler to the intake.
what else can I check. 10-11 mpg sux balls.
Ryan Brown
Rawbrown - Offroad drivetrain, suspension and protection
760-505-9924
Ryan Brown
760-505-9924
