Difference in Regen for towing and not towing: EGTs are going to be higher with less extra fuel dumped in the exhaust when towing, than when not towing. The system seems to struggle to get the needed Regen temps with an engine under light load conditions. The amount of fuel added in post injection that coats the cylinder walls and finds its way into your oil is the culprit in fuel dilution in the oil. The only fix to fuel dilution is to prevent regens from happening, and that is not going to work with emissions. Now the way the truck is used and limits on short low load drives and limits on idle times, things like that might help, but you will not completely solve the issue.
As to "Bluetec" my 2009 also has the badge, it is NOT limited to the SCR/DEF Emissions systems, FCA was Daimler-Chrysler when that system was first put on these trucks, and that is where it came from. It was also in those years when they went away from the NV5600 transmission to the G56 Mercedes transmission.
