I have done some calculations with Excel spreadsheet and it appears the only time operation in unlocked OD might be effective is with a 12 valve engine, 3. 54 rear end, and between 55 to 65 mph while towing. This is the operating range where the rpm would be less than 1800 rpm and known to be harmful to the transmission torque converter clutch. Over 65 with 3. 54 gears you can operate in locked OD (over 1750 rpm). 12 valvers with 4. 11 gears can operate at 57 mph or over in locked OD.
The 24 valve engines have better fuel economy than the 12 valves at higher rpms (see TDR issue number 29). The 24 valve engines are more economical to operate in 3rd locked than OD unlocked. The fuel consumption data in issue number 29 shows the 24 valve uses less fuel than the 12 valve over 1800 rpm, supporting the observation that the 24 valve sweet spot is 2200 rpm.
The major cause of poor fuel milage while towing is air resistance or drag. Increased air drag and lower milage is caused by increased speed, increased frontal area, and increased drag coefficient. With my 11. 5 ft tall fifth wheel, a 5 MPH increase results in about 1. 5 mpg decrease. That 5 inch height increase for flipping the axles will reduce the milage about 0. 3 mpg. A low profile fifth 9. 5 ft high would increase my milage about 1. 75 gpm.
It appears the drag coefficient can be reduced with a wing or by reducing the distance between the truck and trailer. A 1000 lb reduction in weight is good for about 0. 2 increase in mpg.
Best milage is obtained by gearing to operate at the optimum rpm at your preferred towing speed. The optimum fuel consumption rpm is 1500 to 1800 for the 12 valve and 2000 to 2200 for the 24 valve.
As I have one of the 3. 54 geared 12 valves, I will rig a unlock switch and test towing in unlocked OD for the next few months.
