Installing new lift pump and pusher pump at tank, wanting to run a fuel filter before pusher pump. Can I use just a regular Fram plastic see-thru with paper element like you get at Wal-Mart or will the combined psi from lift and 7psi pusher pump be to much for that type of filter? Have read on some filters not to exceed 10 or 15 psi, but very few list psi specs. I'm thinking the new set-up will be around18-20 psi, am I correct?
