I changed out the lift pump again last night. I'm still not happy with the inlet pressures, but that's another topic. I bent the fuel line from the outlet of the lift pump to the canister slightly when I removed the old lift pump. I disconnected the entire filter canister housing from the engine to get everything connected properly. When I went to mount the canister back onto the engine, one of the mounting bolts fell, but never hit the ground. And you know what. That little b%@#&*d just disappeared and can't be found. Does anybody know the thread size on those bolts? The canister is pretty snug with only one bolt, but I don't want to run the truck to long with only one bolt holding that canister to the engine. TIA
John
John
