Fuel Filter change intervels???
will removing muffler lower EGT's
Straight Piped & Lovin' it!
When do most of you change your fuel filter? Every oil change?
Troy
2001, 2500 Black 4x4, Bank Power Pack w/DD1's, DTT T/Q and VB, K&N. Max Boost about 38lbs Pulling a 9000 Weekend Warrior full of dirt toys for the whole family.
1974 Powerwagon, fuel injected 360, custom suspension for that killer off-road ride... . :)
Well I change Mine every 15,000 miles!!!
1999 2500 QC, 4 1/2" SkyJacker lift kit with 36" SuperSwampers
No Muffler, Piller Mounted Boost Gage everything but Leather
auto, 4. 10 LS, camper & tow groups,www.dodgezilla.com
Every other oil change @ 15,000.
'00 2500 QuadCab SLT 4x4,White,5spd,tow package,3. 54,vinyl floor,rear slider,PIAA driving lights,Century "Ultra" matching cap,lost silencer ring. Westin "powdercoat" nerf bars. Rhino lined "rockers" for chip protection. Clearance lights. Jardine 4" exhaust.
I guess I do mine to often as I change mine every 7500 miles, I perfer to keep the fuel system clean and water free.
2001 2500HD Quad Cab SLT SB 4x4, HO Cummins, 6-speed, 3. 55 gears, LSD, brightwhite/driftwood, 4w ABS, camper and trailer tow packages, HD transfer case, snow plow prep, group, cab lights, Isspro Boost and Pyrometer gauges mounted on A-pillar, 4" JRE exhaust, BD exhaust brake, SW fuel pressure gauge. 30,000 miles and counting as of 2/28/01.
1980 CJ-5, Modified for off-road use, bobbed fenders, 350 TBI, NP435 trans, 4. 56 gears, Dana 300, Dana 44 front, Dana 60 reverse-cut rear axle, ARB air lockers front and rear, 15/35/15 Super Swamper TSL on 10X15 steel rims, Cobra CB, Warn 9000I winch, nerf bars, 1/4" steel rock crawler bumper front and rear, jerri can/spare tire rack, custom roll cage.
My Webpage: www.homestead.com/dhatfield2/trucks3.html
Oil change and fuel filter change every 8000mi.
-Mike
'00 2500,QC,4wd,LWB,Dark Garnet,6spd,3. 54lsd,SLT,DD stage II,Psychotty air,10-level PM3,Jacobs ebrake,Isspro pyro & boost gauges,2wd-low,Airoquip fuel lines,Smittybilt nerfs,BFG 285/75 AT's
'95 2500,Reg-cab,2wd,LWB,White/Star silver,Automatic,3. 54,SLT,Michelin 265/75
I perform schedule "B" preventitive maintanence, so that means every 7,500 miles.
<font color=forestgreen>2000</font> DODGE <font color=forestgreen>RAM</font>, <font color=forestgreen>2500 HD</font>, 4x4 SLT, Reg. Cab, <font color=forestgreen>Forest Green</font>, Agate interior, Cummins ISB, Auto, Shift-on-the-Fly (241HD), 4. 10 LS, ABS, Trailer Tow Group, Camper Group, Michelin; DC: Fog Lights Kit, Tow Rings, Under Rail Bedliner, VentVisors, Splash Guards, Cold Weather Cover, & Mats.
<font color=forestgreen>After-market</font>: JRE 4" Exhaust, Van Aaken, Practical Solutions Diesel Products:High Idler, Heavy Duty Idler Pulley, Intake Heater System Saver & HD U-Bolt/Anchor Plate Kit, Gatorback Belt, Painless Wiring, K40, Viper w/AutoStart, Clarion 6 Disk CD w/remote, UnidenCB w/Francis antenna, Draw-Tite Activator II, Alpex 255TC2C Air Horns, Continental BedRails, Delo 400, HOWES, Liquid Glass.
BigDaddy's Ram #ad
New England RamRiggers
<font color=36648B>2001 PT Cruiser Limited Edition</font>
Every 2nd oil change(15k), but it never seems that bad. Almost no sediment in the bottom of the canister. I'll probably start going longer unless I get a bad batch of #2.
Y2K Red Stealth Sport 2500 4X4 QC SLT+, 5-spd, 3. 54 LotsaSpinDiff, 265-75-16 LTX's, DC's dead cow/vinyl interior and 4-wheel AnythingButStop brakes, Roll-N-Lock bedcover, Smittybilt stainless nerf bars. Silencer ring?
Guess I'm the low man here, changed mine at 5000 and will change again at 10,000. Cheap insurance and a great way to smell some diesel (bonus in my book) while tinkering with the truck. I only put on about 12,000 a year and lot of that is short trips, 10 miles or less.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,SPA fuel pressure and temp. gauge,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Lund bug shield,PM tractor utility back up lights,Penda bed mat,365. 8 HP on the dyno and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
I change mine every other oil change (~7,000 miles). I put over 500 miles a week on my truck. I get the Geno's Garage 4-2-1 kit. I guess you guys that don't put more then 12,000 miles on your truck a year might want to change it every oil change.
1999 2500 ST LB 4X4 Metallic Red, 5-speed, 3. 54 gears, LSD, camper and tow package
Westach Boost/EGT (pre and post turbo) mounted on A pillar.
C'mon you guys, mileage doesn't have anything to do with changing a fuel filter. Or an air filter. Either they filter or they don't.
I have 52000 miles on my truck and have changed the filter twice. If I had some of you guys 5000 mile throw aways, I'd never have to buy another one.
A pre-filter, post-filter pressure test on a new filter will give you a base reading and when it starts showing a loss post-filter. Change it.
It won't take you long to recoop the cost of a gauge at $15 a whack.
98. 5 24 valve auto, QC, LB, EZ, DTT vb 9 1/2ft 3500# slide in S&S Camper
Change mine every 15,000. Whether it needs it or not. I have an aux tank and do it for piece of mind. I feel like that is cheaper than sucking some junk in the engine or pump,sometimes I get kinda low on a long trip. I have put 95 gallons in several times,carry 100 when full.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, lock-right locker, 3. 54 gears,ez edge, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
Changed mine at 9000 mainly because at 7000 miles i forgot to do it with the 2nd oil change. Filter was dirty and i will go back to the every 2nd oil change routine. As long as you don't let the Dodge boys do it then every other oil change is very cost effective.
2001. 5 3500 6 spd 4x4 ETH/DEE Quad SLT Silver Metallic. Tow Group,Camper Special ,3. 54, western nerf bars, Towing 99 Damon Challenger 5ver 31' ,Jacobs E Brake . Need :Guages, aux fuel tank, tow mirrors & Cb radio.
2000 Dodge Intrepid R/T. Wife loves it.
I too use the schedule "B" for my girl. Yes it maybe overkill but a $15 filter to save a whole lot of head aches. To each his own.
But then again I changed my engine oil at 500 miles the first time and have been following Sch. "B" ever since. I plan on keeping this truck a long long time. I had a 99. 5 auto and traded for the 6 speed, glad I did.
Sorry so long
See Ya
Chris
2001. 5 2500 Intense Blue Sport 285-16 BFGs mounted on 8x16 Baja
6 speed 4:10 limited slip heavy duty everything, Cab lights, Xenon flares, Linexed Nerf bars, Linexed OTR bed, Brush/grill guard,
tow hooks,no heated seats or leather.
I change mine at 10,000 miles. BTW, I drain the housing periodically and have yet to find any water.
John- n6jwh
Happy Mother's Day! (where applicable) #ad
1999 2500 Club Cab 139" WB, Deep Amethyst Pearl Coat, 24V, 5 speed, 2WD, 3. 54 LSD, Mag Hytec diff cover, Jacobs E-brake, Muffler Eliminator, K&N filter, Black Maxx lumber rack, Delta tool box.
