Not to be a gloom and doom guy here, BUT - think about this in regard to checking pressure periodically rather than a fulltime gauge. My pump has been dying for months. The pressure is all over the place - from 12 to zero. The needle on the gauge will be bouncing all over the place sometimes. It has just recently been consistently at zero enough for me to take it in. On my way to work, I'll see 12 at times, 6 at times, and zero at times - all in the same trip. So, be careful - it can go that way - and it may be running the same the whole time - like mine is. If not for my gauge, I wouldn't have a clue that the pump is bad. The dealer says it won't run on zero pressure, but that's not true - as we have seen from other members here. So if you check it periodically (which is better than not checking it at all), keep in mind that you're just getting a partial picture of what it may be doing. Just my 2 cents. Good luck!
