Reading my new copy of Construction Equipment magazine, I found a section regarding changing fuel filters with tech tips from Caterpillar. One thing they stressed was to NOT pre-fill the filter. The reason they gave was that the fuel you pour into the filter will not be filtered before going to the injector pump.
My question is, if you put the filter on dry, crack the bleeder screw, and then use the plunger to fill the filter, will THAT fuel be filtered as it comes into the filter?
