Originally posted by moparguy
First of all, take every thing you read on the Internet with a grain or two of salt.
Now for the opposing view on changing filters. An argument can be made that your injection pump would be better served by changing the filter at twice the recommended mileage rather than half.
Think of a filter as a series of holes. Some big, some small. Whatever you're filtering will follow the path of least resistance. That would be the big holes. Since the larger passages are caring the fuel (or air in the case of a air filter), they will stop particles larger than the passageway. Of course smaller contaminates will pass through.
As the larger passages clog up, the fuel (or air) is forced to follow the next available path of least resistance, or the smaller unclogged holes. They in turn filter out smaller particles.
Filtering out smaller and smaller particles is a good thing.
This process will continue until the filter clogs and a power loss is noticed. Filters should be changed before that happens since if the application generates sufficient suction, a totally clogged filter can start to disintegrate and then really bad stuff starts to happen.
Will our trucks cause a filter to come apart, I don't know. But I change fuel filters on a much longer schedule than the book calls for and it works for me. I do drain a little fuel at each oil change and it's always clean.
