fuel filter upgrade?
68RFE filter
Smarty Jr on 2012?
cat fuel filter is 10749 no on the tank. that is a 100 gallon L tank i extended a tape measure up and got in the drivers seat. i looked in the mirror and observed the last number i could see. next i took a toolbox made to set on the tank and shortened the box just enough i can not see it in the mirror. now i can see my 5th wheel while backing into the trailer.
Did you build the 100 Gallon L tank and toolbox that sits on the tank, I could not see a manufacturer name on the transfer tank or tool box.
it is a stock 100 gallon aluminum tank i welded a fitting on bottom and drilled a hole in the tank next drilled a hole in the bed for the fitting a ball valve next the sediment bowl filter next a wix 24770 base and wix 33674 filter and then to the filler neck. here is a pix of another truck with the 5th wheel off the rail
