Details here: TDR Privileges
o ring goes on the water sensor thick flat rubber washer goes on the threaded pipe coming out of the filter housing on the block it usually does not come off unless you reach under and take it off
Kenny, the 97 is different. The top one in the picture comes loose with a Fleetguard filter and installs on the top of the housing cone. The other two should be on the filter.
