FUEL FILTERS
Trans. temp. sender
Let me get this right...
I HAVE THE 94 RAM PICKUP. ALWAYS USED THE
FS1253 FUEL FILTER WHICH HAD THE WATER
SEPARATER DRAIN ATTACHED. MY NEW FILTER
{SAME # FS1253) DOES NOT INCLUDE THE WATER
SEPARATER -- THERE IS JUST A HOLE THERE.
CAN I USE MY OLD WATER SEPARATER ON THE NEW
FILTER OR DO I HAVE TO BUY THIS PIECE
SEPARATELY? WILL IT FIT OR AM I IN TROUBLE
IF I REMOVE THE OLD SEPARATER DRAIN AND TRY
TO PUT IT ON THE NEW FILTER?
The filter you are using is the normal non-separator filter. The thing that goes in the hole is the Water In Fuel (WIF) sensor and water drain valve. Unless it is busted it goes in the new filter.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
yellowjacketex,
Are saying every time you changed your fuel filter you bought the filter & drain valve combo?
Thats a major waste of money. I still have the original drain valve on my filter. (94, 110,000 miles)
Unless your drain valve is leaking or cracked or broken (like Missouri Mule said) You can reuse it on the new filter. The new filter W/O the drain valve has an O-ring with it for the drain valve.
The drain valve just unscrews (may need pliers) and remove the old 0-ring. Put a little engine oil on the new o-ring and screw it it hand tight.
Take care
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7 º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno`s Exhaust Blanket,Espar Heater (won it!), Synthetic lubes throughout.
