I built mine. I got the RACOR 690 (R90T 10 micron filter element) from SouthEast Power Systems ( I know the 645 would have been enough, but I only wanted to change the filter 1 time per year (25k miles, 1600 gallons) so I got the 690). The brass ball valve from a good plumbing supply. I the SS fuel lines from Summit.
I mounted the 690 on a 1/4" steel plate that is attached at the top by bolts through the bed stiffeners and at the bottom on angle iron brackets for the running boards. The whole thing is in the under side bed pocket at the front of the bed on the drivers side.
I get into the fuel system right where the OEM tank line comes over the left frame rail (under the truck back by the tank) + about 2 ". Earl has a fitting 3/8 compression to AN-6 that I used to get it into the AN-6 sizes. Then I go to the RACOR 690, then I go to the lp on the frame rail, then I put a Mallory 4307M bypass regulator, set at 12 psi, to keep the OEM lp check valve CLOSED (because the OEM lp check valve seems to be a major cause of lp failure). The bypass regulator is plumbed back to the tank vent line. The fuel line goes on to the OEM ff and on the the VP-44 with all Aeroquip fittings (including the inlet / outlet of the OEM filter and VP) and AN-6 lines (I took out all the banjos and stock fuel supply lines). I left in the stock fuel return line from the VP and engine T. I monitor the fp post lp just before the OEM ff, and post OEM ff just before the VP-44 inlet.
I am testing a workaround to keep the VP-44 from hammering the fp gauge just before the VP-44. I have lost 2 high quality solid state Westach sensors on an 18" snubber line in 2 years. I think I MAY have a better mousetrap by puting the pre VP fp sensor on 120" of fuel line that snakes around the air intake horn in circles and figure 8 patterns to buffer any VP pulses.
The 120" line also makes it EASY to bleed air in the fuel line if necessary. Unwrap enough of the 120" fp sensor line so it can hang over the front grill into a bucket, loosen the fp sensor, and bump the starter, run it until there are no air bubbles (maybe 2 bumps of the starter), tighten the fp sensor fitting while the lp is pumping, re snake the long fp sensor line, and crank her up.
Hummmmm, I got carried away I guess, oh well, now you know,
Bob Weis
The filter is on the tailgate side of the 1/4" slab for protection from road debris.
The cost: Filter is $25, filter head is about $50, ball valve about $25, SS lines and fittings $probably more than the entire filter and valve. Peace of mind PRICELESS (but DO carry a spare lp, it WILL fail eventually, but it will be super easy to change with it on the frame rail).
