I just purchased and installed ISSPRO EV2 HPCR and fuel pressure gauge (14055). The HPCR works great. The question I have is on the fuel pressure gauge. When I turn on the ignition the gauge comes up to 10 psi. It doesn't matter whether it is in the driveway or going down the road but when I run the truck up to 2300 rpm the fuel pressure gauge only drops about 1/2 psi. Is this a normal reading? I read some posts where under load the pressure dropped 4-5 psi.
I double checked all of the wiring and isolated the sending unit and it appears to be working fine.
I searched the forum to find out how to install the gauge and found a few threads where people were removing the lower banjo bolt on the fuel filter and attaching their sending units there. The Kit I received has a Vulcan fuel line and I attached it to the bottom of the fuel filter and the sending unit is attached to the other end. Is this a typical installation or should I be using some other location?
Thank you
Richard
Thank you
Richard
