My fuel guage on my 05 went to empty and the light came on just after filling up . Every once and a while it will read correct then back to empty . I pulled the tank and the sender sweeps from 220 ohms to 20 ohms , there is battery voltage and a good ground at the connector and I don't use the lift pump in the tank or the suction line (Have a FASS 150). I hooked the sender up when I had it out and moved the float arm and the guage never left empty . Does anybody have an idea where to go from here ? Thanks
