Save yourself a lot of trouble and get the marine grade rubber hoses from any commercial boat shop. They're pretty much diesel proof, regular fuel lines from the auto shops will crack, develop pin holes and suck air and need replacement in a short while and you'll be back here again. Also, use stainless hose clamps you can use a nut driver on instead of a screwdriver. The lines are truly a PITA to replace, so remove the fuel filter to get some extra room (probably needs changing anyway, eh?). If your feeling itchy that day, pull the starter and then drop the strainer on the bottom of the fuel heater and clean it out too, and while you have all that out you'll have more room to change the lines. While you've got the starter off replace the solenoids' contacts with a set of Larry B's heavy duty contacts (a miraculous invention indeed). If you do all of this (May take one of your buddys and a 12 pack on a cool weekend day to see it thru) but you'll have solved a basketfull of nasty, troublesome, @!?X$$! problems. Your truck will run better, start better, feel better... ..... and you don't need a basket of fancy-dan tools to do it..... happy motoring!!!!
