This has been an ongoing thing for my truck for the last half year, or maybe a bit more.
I injured my back and hip last year, so I haven't been able to spend a lot of time leaning into the engine bay.
History, nothing had really changed recently when this started. It basically would have the typical no start, let the LP run it's cycle once or twice, and it starts. After it's running, it would restart just like normal. As the days went by, the time needed for leak down to occur grew shorter. It started around an hour needed before it happened, but got to the point that 10 - 15 minutes would be enough for a no start.
I changed out ALL my inlet fuel lines from the vulcan draw straw, with a straight run to the LP's on the frame (took out the stock line that goes next to the tank and ran all 1/2" line).
All line is 1/2", all fittings are good, and all o-ring seals are new.
After that, I replaced the fittings on the T in the return line because they showed a little seepage. This helped a little, but the problem remained.
I have checked and replaced any line or seal in the fuel lines, both inlet and return.
I pressure tested the valve on the VP, opens around 14psi like it should.
My back was feeling good enough to take out the injectors a couple weeks ago and had them tested. Two of them were bad, but no surprise there.
Right after I did this, it started back up like normal. No leak down issue. Actually, it was the opposite in that if I had the LPs running with full pressure, it wouldn't want to start as easy. GREAT, like it should be!
But that didn't last long.
It still has the leak down issue, but it isn't AS hard to start now. This also might be because it's warming up some as well.
Ok, what's left?
The tubes looked fine when I did the injector install.
I put back in my stock injectors. They need a good cleaning, but they never had any leak down issues when I had them in before.
I am waiting on Don M to finish moving so I can get my injectors worked over, so I am stuck with the stock injectors for now.
Would the o-rings on the injector tubes even be able to cause this?
And what other component might I be overlooking?
Should I replace the valve on the VP anyways? This keeps sticking in my head, but it doesn't make sense when it passes the pressure test.
Btw, this only happened a while after the HRVP44 install. Never on the stock VP.
My back is getting better, and I REALLY want to get this issue fixed!
Ok, what's left?
