This has probably been discussed before. I know that Cooker gave the part numbers to replace the the fuel heater and the wire harness. When starting my truck yesterday I notice, once again, that it took more than a few turns of the starter before the motor fired. Well I began to look for a fuel leak. Things that I replaced last month, return and supply fuel lines, the new WAIF valve I installed in July was causing loss of prime so I replaced it again and seems to be holding. I noticed the pumpkin on the front axle was damp and I found fuel on the connector on the fuel heater. I notice about three months ago the temp sensor and wiring were melted to the point that one wire was burnt into, also the heater measures infinite resistance on the Fluke 87. I have the part numbers for the sensor wire harness and the fuel heater. When replacing these parts will this also take care of the fuel leak? Also will this leak cause the engine not to fire on the first bump of the starter?
Thanks for your time.
