Ok correct me if I'm wrong but the two lines that run up the firewall at the back of the motor are supply and return correct?
I thought I had a hole rubbed in what I thought was my metal fuel return line. However, after diving into the project it appears to be the supply line instead. Seems that the return line is a lot longer piece of hose than I though and it ends right at the end of the injection pump and turns to metal.
The other line goes directly into the top of the fuel heater which leads me to believe that is it a supply line. Where the supply line goes from metal to rubber at the firewall its very damp on that end of the hose, appears to be leaking fuel as I checked all of my metal lines and they don't have any holes in them.
Probably a dumb question but is this common, just like the return line dry rotting and causeing hard starting?
