Serviced the truck Saturday ( oil, fuel, grease ), relocated the breather bottle, noticed Sunday she's leaking a little diesel. Double checked the fuel filter cap; snug tight could not locate the source. Cleaned drivers side of block etc. and drove it today ( block was a little moist behind and below P/S pump, but bottom of fuel filter and the infamous lift pump assembly was saturated with fuel. Cleaned it again and i think I've narrowed it down to the line coming out of the fuel fiter: looks like two seals along with the bolt and tube.
#1 can I snug up the bolt ( looks like a 15mm ) to stop the leak, or
#2 do I need to replace the seals ?
#3 noticed a little leakage where the P/S pump and Vacuum pump meet. Do i need to worry about it also ?
P. S. No codes
P. S. No codes
