Hey Guys,
Just replaced supply & return lines to fuel tank with marine hose. Old supply line running along frame under cab started leaking due to corrosion so I replaced both from engine up to the point on the frame just before the tank. ( you know you can't access this section easily without dropping the tank, didn't want to do that, half full ). Since finished, engine still doesn't want to start easily. Cranks,cranks, then starts rough. While under the truck, I also eye-balled the sending unit on top of the tank. ( you CAN get your head up in there ). At the spot where the supply & return lines enter the tank is also rotted to where the pair of them are loose and kind of laying there together. My question is, would this rotted away connection on top of the tank also create a hard start? Should the tank be somewhat pressurized also for correct operation? (no leaks?). Napa says the sending unit is a dealer item only (ouch). Don'y want to buy it if I don't need it but if it fixes the problem, I'll have to. Everything else visibly in fuel system looks OK and filter is new. Haven't touched pre-heater yet either. Any input would be appreciated, winter's coming. Thanks very much. Mike
