Engine/Transmission (1994 - 1998) ? Fuel lines
Engine/Transmission (1994 - 1998) transfer case woes...
Engine/Transmission (1994 - 1998) exta power
Anyone know the sizes of the two soft fuel lines? These are the supply and return lines. There both diff sizes. Also, whats the length?:D
Yea I know about them, I live pretty close to them. However, why pay 14 bucks for several feet of marine quality hose that should only coast you about half. I can go to the boat place and get the same and not drive as far or pay as much. Thanks anyways. :D
5/16 and 3/8 not sure of the length when i did mine i bought 5 ft of each but I did the ones on the tank also and there plenty
3/8" ID = supply
5/16" ID= return
a 24" piece of each should be sufficent for any trimming
mistakes.
94-97's have a 14" +/- supply and return. I slit the old ones with a razor blade and cut my new hose to to length from the old one.
98's only need a short rubber return line that's about 7" long, remove the fuel filter can and base from the intake for easy access. The supply is a "quick connect design. "
