2015 Eco Diesel, 1500 4x4, crew cab, ordered from factory received in March 2015.
Just a note, the Eco Diesel truck the dealer had on the lot and wanted me to buy was bought by someone else. Accoding to the dealer they lost the engine at 5,000 miles, oil getting into the cooling system. It took two months to get a new engine. The buyer had so many problems with it after the new engine installation, they traded it in on something else.
Now to my EcoDiesel, I had the dealer change the oil at the recommended 10,000 miles and take a oil sample on orginal oil. They said I was the first to take an oil sample on this engine? They then did the upload so as to stop the hackers from taking control of the new vehices, since that date and time my mileage has went from a consistant 28-29 mpg to 24 mpg being the best. Dealer claims this has nothing to do with either of my problems. This is traveling the same weekly drive with me as the only driver. Also the oil sample showed 4.8% fuel dillution. I've taken oil samples on the new oil, second oil change, at 5,000, and 7,500 miles, both showed 5% fuel in the oil. Changed oil at 17,500, third oil change and will continue take oil samples. Dealer and engineer say this normal for that enigne and the poor mileage is do to the cold weather, 70' F here now and it is doing worse on the milage as it get warmer, 17.8. Contacted oil manufacutre and they stated this is not good for the oil or the engine. 5% dilution = 16.8 oz (2cups) of diesel fuel in the engine oil of 10.5 qts. Talked to many other owners of this same truck and engine, they've had many other problems with mileage being just one of them, 20-24 mpg, but could not conmment on the fuel in oil because they never had the oil sampled.
Checked dip stick right after the oil change, right on the full mark. Today with 22,237 on the vehicle and 5,737 miles on the oil, the oil level is 3/16" above the full mark. Will be doing another oil sample this week and staying with changing the oil at 7,500 miles, which are costly, instead of the 10,000 mile recommened oil change until the fuel/oil dilution problem is solved or I'm convinced that it is not a problem for this engine.
Has ony one had or heard of these two problems? Is it an out West problem only?
Need help and information.
