2nd Gen Non-Engine/Transmission Fuel P/U
Engine/Transmission (1998.5 - 2002) Hard Starting 24v
Engine/Transmission (1994 - 1998) no tach and no charging
Hi all I'm looking at trying to replace my fuel P/U in my tank. I know that the 90* elbow at the top of the tank is real small. Has anyone pulled the stock P-U tube and the 90* at the top what fittings did you use and how long is the tube what did it cost you? TIA
Jannetty makes a kit and possibly Van Haisley, Enterprise or Scheids or you can do it yourself with some copper pipe and fittings--I did the Jannetty one but ended up putting a hole in the bottom of my tank(3yrs ago) to be 100% gravity fed---chris
I puled mine and will post pics if I ever get my laptop back from Best Buy. The fittings are 3/8 quick connects on top with a straight hose connect on the inside. A small crimp type clamp holds the 3/8" rubber hose to the fitting and the bottom is press fit onto a plastic pick up tube/screen assembly on the bottom. The return is the same except 5/16" and the rubber hose on the inside just dangles into the fuel module. I am looking at fabricating a new fuel module alltogether. Anyway hope this helps.
