Fuel Power diesel additive?
Ranch or Honey Mustard with my fried SBC OFE?
Airdog owners
http://www.fppf.com/fuelpower.asp
Anyone try this stuff?
I used some for the first time in the big truck. Unless it is a fluke, I gained . 2-. 5mpg using this stuff, of the 4 fuel fill ups. Even had 14hrs of idle time with one of the tanks that avg up with . 4mpg higher than normal. Should've had about 5. 0 with the winter fuel, but had 5. 5. The fuel was purchased from 4 different truck stops, so no connection there.
Ran 2 of the 8 oz. bottles so far. It treats the same number of gallons as a 1/2 gallon of Howes (which I normally run), and is much cheaper by almost half.
If I can find it locally, I'm gonna keep using it, and see if it is consistant at all.
yep
I have been using the Arctic Power the last 3 or so winters. This winter I switched to the Total Power, and when it warms up, I will be switching to the Fuel Power with lubricity thanks to the new ultra dry fuel. A local trucking company and the parts house both stock fppf.
I have been very satisfied with the results. I havent checked mileage using it, mostly because I havent used it in the warmer months.
