JLandry
Hi everyone,
I just relocated my Airtex E7153 gearotor type lift pump down to the frame rail just ahead of the fuel tank. The relocation kit included all the necessary components to replace the fuel line from the tank up to the OEM filter canister. It also included a small standard automotive fuel filter to use as a pre-filter between the tank and the lift pump to prevent the possibility of crud from the tank from ever clogging the lift-pump. It looks much like this:
I went ahead and installed it, but now I'm starting to have second thoughts about it because I have two specific concerns:
1. It has a very small capacity... much smaller than the OEM filter... so to be safe I'm going to have to replace it often. The good news is it doesn't seem to be restricting the fuel flow appreciably.
2. Because it's not heated, it could quickly plug from wax if the fuel gets really cold.
Can anyone recommend something better for this application... like maybe a heated pre-filter with something like a 100 micron cleanable or replaceable screen? I'm looking for suggestions on specific brands and model numbers if possible.
Oh... and the fuel line I'm using is 3/8" ID.
In the mean time I'm searching Google but I'm thinking someone here much have already been down this road. No need to reinvent the wheel.
Thanks in advance,
John L.
Thanks in advance,
John L.
