Hey Bill, Good to hear from you again. Hope the move went as well as moves can go.
I figured that there was a continuity problem there. The sender has a separate ground post so no problem there. Like I stated above, I made sure that the pipe dope could not get into the line. It's working fine. Readings are sort of middlin' as far as pressures go. At least I can tell when it's too low. 2 psi is the lowest at WOT. Not great, but it does have a few mods on it. Banjo bolts are next.
Take care.
Tom
