Joe G. said:Eric,
I've been away from this thing for a few days. There is a last resort thing to do to check the pre-fuel filter system for leaks. Take it all off: steel lines, lift pump, and fuel heater/pre-filter. Put it all together and restrain the cam follower plunger with something so pressure does not pop it out of the pump. Presurize the whole mess with about 20 PSI of air. Put it in a five gallon bucket of water. I had to do that once to find the leak. It was the fuel heater in mine. Another guy found a bad fitting that looked good but many bubbles when it was in the bucket.
I'm sure glad you replied Joe, but I hope it dont lead to this.
I think I'll get a clean piece of cardboard under tomorrow, then run 5 psi to the tank for an hour or so.
Sit back in the lawn chair, have a cigar and see what happens.
I've been degreasing the heck out of this for the past few days, and it wasnt even dirty before that, if there's something leaking, I HOPE it will show up then. :{ :{
I'm ordering an overflow valve also tomorrow just because I dont want to go through all that. :{
Eric
