I bought this truck about 2 weeks ago and have no problems with it yet. It came with guages (fuel, EGT, Boost) as well as the 5 stage comp and 16 cm housing. The pressure has been constant @ 11psi @ idle with the comp on setting 1 through 5. I have heard that the pressure should be about 14 or 15??? Also, the first week I ran off road (high sulfur) diesel and I enjoyed the nice black smoke I left behind when I punched it. The next fill up I used low sulfur diesel and also added STP diesel additive. After a few days I noticed that with the comp at level 1-3 I got white/slight gray smoke and on 5 I got dark gray/black smoke. I know that the high sulfur burns black but I have seen in other post that the white smoke and low psi is early sign for a bad lift pump
Any ways to check the pump?
How can I make sure the Fuel pressure gauge is setup right??
