"Fuel Pressure,Boost, EGT Gauges" for a 2005
T/C unlock switch ?
NV 5600 rattle and hot
Can anyone reccomend the LEAST OBTRUSIVE Gauge setup/package for the a 2005 6spd 4wd cab for FUEL PRESSURE,EGT,BOOST??
Thanks!!
They don't show the actual picture for a 3rd gen but it's similar to a 2nd gen just mounts closer to the windhsield. I used Isspro gauges with this.
Auto Meter
SHadrach
Look in to the edge att. with juice,has gauges and five power levels. However i dont think it has fuel pressure gauge. Just get a FASS lift pump & no more worries about fuel pressure,then no need for the gauge.
I have the same dash mount as AH64. I use to have them on the pillar and to me it looks cooler up there but for my scan, the dash mount pod is easier to see and less of a distraction. It was also much easier to install than the pillar mount.
If you are willing to lose the cubby hole in the dash the gauges can be mounted there. Autometer makes an accessory for it and it is sold by Geno's. Ed B
Losing the cubby aside, that seems to be too far from the line of sight for important gauges like boost/EGT... I could see oil pressure, air bag pressure, drive pressure, stuff that doesn't need to be seen with the road.
That's the dash pod I was talking about. I have Pyro, Boost and Fuel Pressure on the dash and Air Pressure ( for Kibly OBA ) in the STR10 pillar pod. Shadrach
