My gauge "buzzes" with the rapid FP variations I get. PIS drops to 7PSI at times and a snap on the APPS pedal and back to 15PSI.
Been this way with 3 different LP's and OEM fuel lines and a Vulcan big line kit.
I even hardwired the LP to the battery to rule out voltage varitations, same old BS.
Tomorrow I put the snubber back to quiet the gauge down.
Tried a clear line to check for bubbles, none. Same full or empty.
Tried a new bypass regulator at the VP, no change.
Pressure is constantly varying too, even on level ground.
Just about to go mad or get a common rail ( already looked at an 06 auto 3500 DRW)
Possible the vane pump inside the VP is messed up?
