Fuel Pressure Gauge "buzzing"
How to test MAP sensor?
All New Hampshire owners
After i installed my 0-35PSI Sport Comp Fuel pressure gauge, i now get to hear my injection pump wherever i go. I am using the pressure port on the pump as my gauge pressure source. I know moving it Pre filter will solve the problem, but is there any other quick fixes before i try that?
Wow, that will be perfect, THANKS!. Can i just order it online from them? Also, do you know off hand if it will screw right in? or will i be searching for fittings to make it work?
EMD, if you have a credit card you can order online. The snubber comes with 1/4" NPT ends, if you are useing 1/8" fittings use a 1/4 x1/8 brass bushing in the female end. On the male end the ID of the snubber is just the right size to run a 1/8" tap down it.
