Hello,
I'm about to install an Autometer 0-15psi gauge and oversized banjo bolts and can I get by using 1/4" rubber line and some quality barbs and clamps from the pump to the isolator or is it necessary to use the braided high pressure line?? I see the line from the lift pump to the filter is rubber and the pressure should be at 15psi or under and it won't be rubbing anything so does that mean I can use this type of line? I only need about 19" of line and all I can find for the braided stuff is a 36" line for $45. Also, the line that comes from the filter to the VP44 has what looks like a bleeder on the banjo bolt is it OK to change this?? Will I ever need this bleeder?? If someone could please steer me in the right direction I'd sure appreciate it. Thanks, Kampinkid
