Engine/Transmission (1994 - 1998) Fuel pressure gauge readings
98 12v auto
just put in a new fuel pressure gauge and the readings are
idle is 19-20 psi
2000 rpm is 2400-2600
does the second reading seem a little low to you guys?
Thanks
Hey Bud, the factory service manual for '96 trucks calls for a minimum of 25 psi, with no more than a 5psi drop across the filter/separator. The 25 psi reading was to be taken at the inlet to the filter. I assume the info. would be the same for your '98 12 valve. If you believe you have a problem, check your lines from the tank and your overflow valve. Someone else may have some more suggestions as well. (I assume you meant 24 - 26 psi at 2,000 rpm's. )
my 2000 rpm reading is 2400-2600 with no load.
Dont kow if it worth it to get a new overflow valve.
I also see new drop in pressure at 2000 rpm. it stays constant
Thanks
