Fuel pressure gauge,were can I find one
NEED A PHONE #
Overdrive
Ive checked all through the post,and links but I cant find any fuel pressure gauge,found everything eles but not that,anybody know were I can find one. Thanks
Dave Foster:
2000 3500,Light Driftwood,Quad cab
4x4,4:10 gears,Westach Gauges,K&N,Auto with DTT VB and TC,DD1 injectors and Boost Module,Van Aakens,Muffler and Resinator removed,Amsoiled front to back.
Member of the GLTDR.
Try a search on fuel gauges, someone found a Stewert Warner that reads 0 to 16 p. s. i. if I remember right.
ex Ford tech, now driving '01. 5 2500 4X4 QC LB ETH/DEE SLT 3. 54, Patriot Blue
[This message has been edited by 85CJ (edited 04-19-2001). ]
Check out www.summitracing.com They have a 0-15psi gauge in several sizes and styles in an electric version or even better, a mechanical version that uses a high pressure isolator so there will not be any diesel fuel coming into the cab. That mechanical version is like 80 or 90 bucks last i remember. If you dont see it on the site, call them at 1-800-230-3030 and ask for the tech department. And no matter what they say, You CAN use the gauges on a diesel. Call Autometer direct if you have any doubts.
I have a Stewart Warner fuel guage. Go to www.xks.com. They have the senders as well.
1999 Dodge Ram 3500 Quad Cab 2wd; 5 spd; 4:10 LSD rear; Mag-Hytec differential cover; US Gear EGT and Boost gauges. Stewart Warner Fuel Pressure Guage with dual senders. Amsoil foam air filter and synthetics from nose to tail.
Cummins Power, don't leave home without it
EMDIESEL,
I just ordered some 2 1/16" Autometer gauges from Jegs and Geno's. Here is a list of what I ordered:
1. xxx-4313 Ultra lite mechanical fuel
pressure gauge with isolator (0 to 15 a psi) 109. 00
2. xxx-5249 Ultra lite EGT gauge 99. 00
3. xxx-4365 EGT probe kit 49. 00
I ordered the following from Geno's Garage
1. 4305 0-60 PSI boost gauge (ultra lite) 50. 00
2. 17205 Triple full pillar (gauge holder)
52. 00
Where xxx = 105 for Jeg's part number or
ATM for Summit Racing part number
I ordered the boost gauge from Geno's because it was cheaper.
Also, I was told by the Jeg's tech that the mechanical fuel gauge comes with an -4AN fitting so it should screw into the pressure port on the back side (near firewall) of the filter housing.
I'll let you know how my install goes in about 7 to 10 days.
Charles
2000 QC 2500 4x4 LWB ETC/DEE, Anti-Spin, 3. 54, Trailer Tow, Camper Special, DD1's, PS boost module, PS high idle kit, PS steel idler pulley, Westin nerf bars, Rhino Liner
My Toy
1969 Toyota Land Cruiser FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars/skid plate, GM tilt steering column, 6 point roll cage, RCI racing seats with 5 point harness. Conquered Tellico and going to Moab this May. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
Try xks.com, thats where I got my stewart warner gauge and sender. It works great and only took a couple of days to arrive.
1999 2500 Quad cab 4x4 auto,Forest Green Sport,Banks Stinger-Plus,pyro/boost/fuel pressure gauges,Smittybilt nerf bars,Smittbilt Outland grill and brush guard,Tuff Country leveling kit with SX 8000 shocks.
