To be honest I never really tried to see how high I could get it. Tonight I didn't do any box off runs. I do remember 19,500 about a month ago testing with a temperature channel. Good point and reason to buy from a manufacture that will be up front about pressures. Well I know they are ready to order anyway but I should confirm the high end readings with SPA. Originally I was just using my Vantage meter and referencing the transducer specs dan. poitras posted to compare with and get my pressures. Later on I set up a SPA temp channel per SPA’s instructions and called it good. Tonight I ran the Vantage right along side a SPA boost channel and they didn't zive even though the SPA was set just the way the engineers said to.
- 0 psi = . 50 voltage return (VDC)
- 5801 psi = 1. 39 volts
- 10153 psi = 2. 06 volts
- 14504 psi = 2. 72 volts
- 20305 psi = 3. 61 volts
- 26107 psi = 4. 50 volts
Box maxed out I saw a solid 4. 56v (not in min/max mode) at WOT above 3000 rpm on my Vantage, looked over at the SPA and it was at 23,80.
This was with the SPA's FCS set to 261 and SPn set to 4. 5v so I should have seen at least 26,10
Something is wrong with that and I have sent off another email to John in engineering.
Also it’s possible the above spec chart is not correct. Chapter 14 page 69 of my factory manual states fuel pressure can be delivered as high as 23,206 so I am wondering now about that chart. I am going to send a PM to dan. poitras and ask about where it came from, it could even be a mis-print but telling the gauge to read 26,10 @ 4. 5v. and only seeing 23,80 at a true 4. 56v is wrong for sure.
I might do some more testing on Sunday. .
