Fuel Pressure Isolator question
Mobil 1 Truck & Suv $4.77 Qt
I'm a member of the South Bend Clutch cult!
Originally posted by jtisdale
Now that I have installed my PE, the needle resides where the 18 should be on the face. (too bad its only a 15lb gauge)
Call Autometer and ask what the limit of the gauge is. :eek:
I'll save you the trouble. 10% of the sweep is the max. That means a 15psi gauge is only good as long as you don't exceed 1. 5psi over 15 (16. 5psi). After that, it bends the internals and throws off the calibration.
This is why we use a 35psi gauge.
Originally posted by clawson
So will diesel fuel hurt isspro guages?
I have been told that it will NOT hurt the Isspro gauges.
Wildcat sells Isspro EV Fuel Pressure gauge kits with no isolators and no problems that I know of FWIW.
Duane
You are right Keith, I do need to get a new one, along with a new boost gauge. :)
But I didnt realize it would screw up the gauge. Thanks.
